looking to get a fan controller, I've already got the scythe kama but unfortunately I can't use it in my fractal because of the front cover. So I'm looking into something touch screen
This^ I currently use it in my system.Originally Posted by mwl5apv;13037444
the nzxt sentry 2 is a good controller. touchscreen, 5 fans, temp probes, etc.
I personally used it myself and liked it alot.
Only issue I had was that it made my fans make a weird grinding/clicking type noise. This was a known issue with my fans though(cooler master R4 120mm)
Your should be perfectly fine though.
Those are PWM. Did you buy them yet?Originally Posted by phaseshift;13037397
5 fans...don't really know much about how much power etc...going to be using 5x 120mm Noiseblockers XLP
Oh I just ment I like the dials ,, just my opinion/taste. I probably shouldnt have said anything.Originally Posted by Gunderman456;13037472
NZXT fan controlers are touch screen. Been using mine for over a year with no problems.
No I haven't but I'll prob get the non pwm since I'm getting a fc. Btw do I need a molex connector for the nzxt? I don't have any molex on my psuOriginally Posted by gymenii;13037519
If you're budgeted, the NZXT Sentry2 is the way to go. 5 channels, 10w per channel and should be able to run all your fans (but limited to run more than 1 fan per channel).Originally Posted by phaseshift;13037773
hmm I might just go with the lamptron it looks slick and performs well...either that or an aquatuning but that one is most expensive lolOriginally Posted by gymenii;13038366
If you want higher quality and don't mind spending a few more bucks, get the Lamptron Touch. 6 channels, 30w per channel and will easily run 2 or more fans per channel, and if you get higher power fans later on you won't have to worry about replacing the fan controller.
overclockers.com Review
Performance PCS + video review
Surely all newer PSUs have molex connectors. If you don't have one available, you'll need to get a 4-pin molex y-splitter if thats what you meant.
