1 - 13 of 13 Posts
have you considered Demciflex filters? They work really well, are easy to maintain, and in my opinion, they don't ruin the look of most cases.
Discussion Starter · #8 ·
Originally Posted by D311;15266786
I've tried them all and my favorite so far is the modright http://www.frozencpu.com/products/9589/ffi-35/ModRight_FilterRight_140mm_Black_Aluminum_Fan_Filter.html?tl=g47c223s885
There are full square ones for 120mm guess not for 140mm. But they work great and the air restriction isn't nearly as bad as the majority.
Of the 2 you listed I'd go with the first.
Yeah that one does look nice, however I do need 140mm.
Thanks for the insight.
pretty sure if you just cut a piece of dryer sheet into a square and just screwed it on with your fan, it would be fine. not much modding required. its not like you need a drill to drill through a dryer sheet....
Discussion Starter · #11 ·
1 - 13 of 13 Posts
