1 - 10 of 10 Posts
Scythe = 110.31CFM , 37dBA
Silverstone = 110.03CFM 39.5dBA
So Scythe provides a little more...hardly a difference though..
However The Silverstone pushes less air and is noisier, so I'd pick the Scythe...
Your choice though, is the $4 worth it?
~Powelly
They are very similar.. are you looking for a quiet fan? Or just one that pushes alot of air..?
Same first is quieter.
~Powelly
They push the same, .3 and .31 are the same.
I use a couple of slipstreams. They're not quiet.
This is with my fan controller turned all the way to low, my single slipstream (110cfm) @ 800ish rpm is louder than any/all of my case/gpu fans.
Out of the two the OP picked the SlipStream is the quietest and pushes the most air....
just one that will cool my cpu better. i currently have a xigmatek s1284 and the fan on just don't cut it. right now my e6600 o/c'ed to 3Ghz on 1.38 vcore can go up to 56C on load.
i just thought that the higher the rpm, the more cooling it gives.
cheers guys
Jesus! 37dB is will make you deaf...
1 - 10 of 10 Posts
