1 - 6 of 6 Posts
Discussion Starter #5
Well, the [email protected] only ran at a max or 50% (or ONLY 2-3%....[weird]), unless I opened up the Display viewer which ran my pc at 85-100%.
I did find this to be the best answer:
I ran 2 instances of [email protected] (uses the command prompt) and that MAXED out my CPU to 100% (50% for each core). For the heck of it, I'm even an running the [email protected] It shows it as "Core is not running" but its in the Task Manager running at 0-2%. The status says working....
The GPU won't use the CPU. You'll also need the SMP client
1 - 6 of 6 Posts
