1 - 20 of 30 Posts
yo guys
I made a thread about this earlier if i should wait for the 7xxx series to release so the 5xx series from nvidia would drop prices but they didnt..
So, I'm playing on 1680x1050. I play bf3 mainly and I would like to know will a 580 run it on ultra and never dropping below 60fps?
I might upgrade to a 27 later also. SO, should I get a 580 or Should I get a 7970? Is the price difference worth it for my resolution? I'm not realy for AMD neither so...
What Id like the most is waiting for nvidia to bring their new series out, But I dont want to wait like another 4-5 months.. So Should I get a 580? Or maybe a 570?
Thanks !
4kfan
DO you want the best? if so get the 7970. do you want the cheaper one. get the 580. a 580 wont be able to get 60fps at all time on ultra. two of them will.
Reactions: Maximus4
You have a very nice rig
I Would say maybe catch some one selling a pair of 570s or 580s in the for sale. But I run a single 570 and it is a beast. The new 7 series will probably be awesume. But really down to earth here it boild down to performance and how much $ you have and want to throw down. The 570 would last you a long time and keep you happy. Having said that DX 11 is around the corner, And you will be ready .
Check what owners are saying about it at the egg might help ya.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130593
Thx man
But I wont go for reference card. The DCII
A 580 today with your currently resolution should be able to max out BF3 on ultra with 60 FPS. If and when you go to 1920x1080, it may not. Since the price difference is minimal, I would get a 7970. If you look on OCN, there are some decent deals on 580s used to save a little money, or you can wait for their price to drop. If you want instant gratification now, just order a 7970.
Reactions: Maximus4
So the 7970 will be never drop below 60 and neither on a 27" screen?
I.T. Specialist III
1680 X 1050?
Heck a 6870 could almost max BF3 with many/most of the goodies on at that resolution.
Standard 27" resolution? 1920x1080? 1920x1200 I think.
Discussion Starter · #11 ·
Originally Posted by amstech View Post
1680 X 1050?
That's not what I asked for. A 6870. HAHA good one:thumb:
I.T. Specialist III
Discussion Starter · #13 ·
For Ultra settings I would say a 570/6950 atleast to run smoothly.
That resolution does make it easier though.
Can't you read ? I might upgrade to a 27 soon. I want to be future proof.
I.T. Specialist III
Can you read?
I posted a link to the review, it shows 1920 X 1200 and 2560 X 1600 on ultra settings, also displaying GTX 580 SLi.
Discussion Starter · #16 ·
Can you read?
1680x1050 on a 6950 gives a min fps of 35. What are you talking about:doh:
You might want to post up WHAT 27" monitor you are looking at. Cause you are probably looking at either 1920x1200, 1920x1080 or 2560x1440 depending on the model. Which will help them out suggesting a card you want.
Discussion Starter · #18 ·
Originally Posted by TinDaDragon View Post
So? a 27" that runs 1680 x 1050 will have the same results as the above chart. Assuming that the resolution is 1920 x 1080, a 570 will run flawlessly, as will a 6950
huh ??
A 27'' at 1920 DUH
Discussion Starter · #19 ·
I don't know yet which one. But it would be 1920x1080 or 1920x1200.
4kfan
a 570 wont max out bf3 on 1080p neither will a 580. at least not at 60fps. trust me i know.
1 - 20 of 30 Posts
