1 - 12 of 12 Posts
Hi guys
So I'm hopefully going to upgrade soon to a 5770, and my main issue is cooling. As far as I can see the only difference between the models are the fan, none of my choice comes with a game.
So these are my options:
Which cooler is the best?
Thanks for the replys, but please stick to the cards listed. Other cards are either not available or out of my price range. That MSI card is 20 euros more expensive then the others, is it really worth the extra cash?
Couldn't you get 20 more euros?
semi-legit
If you have to chose from that list, go with the V1 reference cooler from Powercolor; the aftermarket cooler designs above do not have sufficient cooling for the memory or VRMs.
Discussion Starter · #9 ·
I looked through Guru3D benchmarks and on average it got 1 more fps on games. I'm not planning on overclocking because I think my PSU would die. And I'm not shelling out 20 euros for one more frame.
semi-legit
That was while running the card stock at 875/1200, believe me you'll see more than 1fps difference once you push that card
While only a synthetic reference; G3D averaged over 10fps more in their vantage testing with their OCs.
Again, if just sticking with the cards from the list, go with the Powercolor V1.
1 - 12 of 12 Posts
