1 - 5 of 5 Posts
dark green- temp 1<br />
red- temp 2<br />
grey- HD0<br />
blue- HD1<br />
light green- core<br />
<a href="http://imageshack.us" target="_blank"><img src="http://img211.imageshack.us/img211/6092/spfan2pu0.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /></a><br />
<br />
Which one is the cpu? On the old version of speedfan, it seemed like it was temp2, but in this newer version, it shows "core". Is that the cpu? That temp would be too high for water cooling IMO. This is a pic like 10 mins after startup.
Should be 42c "core"<br />
But I could be wrong <img src="/images/smilies/redface.gif" border="0" alt="" title="Embarrassment" class="inlineimg" /> never been a fan of speed fan.
Isnt that kind of high for custom water cooling, in a ambient temp of 68F? I want to think that its temp 2..... lol<br />
anyways, my vcore is 1.55, and I am running prime 95, overclocked to 2.85ghz
42c ...Is that under full load, if so that fine even with WC, @ idle not so good.
Discussion Starter #5
well, that temp is 35 idle, abot 42-43 load, the temp2 is 29-35
1 - 5 of 5 Posts
