which is better 4 gb at 2000mhz or 8 at 1600mhz?
410 Views 4 Replies 5 Participants Last post by  gablain
I have a 790i digital board I was wondering if 4 gb at 2000mhz or 8 gb at 1600 mhz of ddr3 memory was better I think that 8 gb will be better in the long run whats your opinion?
1 - 5 of 5 Posts
Mostly yes, though it really comes down to each application individually for rendering.
4gb for benching, 8gb for everything else. Basically, get the 8gb kit.
8 gigs is overkill at the moment i think. You're better off buying 4 gigs of fast ddr3 now, and in the future, when you'll need it, it will be much cheaper
1 - 5 of 5 Posts
