1 - 4 of 4 Posts
G.SKILL 1GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) System Memory Model F2-6400PHU1-1GBNR - Retail <br />
Cas Latency: 5<br />
Heat Spreader: Yes<br />
Manufacturer Warranty: Lifetime<br />
Timing: 5-5-5-15<br />
Voltage: 1.9V-2.0V<br />
or<br />
G.SKILL 1GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Desktop Memory Model F2-6400CL4S-1GBPK - Retail<br />
Cas Latency: 4<br />
Timing: 4-4-4-12<br />
Voltage: 2.0V-2.1V
Overclockiit
Thats better lower cas and higher voltage means better potential for higher overclock.<br />
<br />
<br />
Voltage: 2.0V-2.1V
The "NR" Series (NR is the model, the 2 last letters of the name) are absolutely not good for overclocking, so the last ones you posted would suit you better (The PK ones), but there are absolutely better ones.
lower latency = best<br />
<br />
SiSandra 07' tests your RAM's bandwidth capability and speed. The diffeernece between 4-4-4-14 and 5-5-5-15 can be up to several hundred MB's! This means; if two different RAM modules operate at the same frequency, the lower latency RAM will operate more efficiently.
1 - 4 of 4 Posts
