1 - 10 of 10 Posts
· Still kinda lost
Vivobook 15 seems to be a good budget laptop
· Politically incorrect
Any laptop will do. Even a 4W Intel Atom APU such as the 3735 would be fine for his needs, so get whatever is in his price range.
My five year old A8-6410 is perfect for Linux, it performs much better under Linux than Windows but I have to use Windows as Vegas Pro is problematic in Linux (rendering is much, much slower than Windows).
Edit: I would recommend looking into a laptop like mine. Older CPU's/APU's still perform perfectly fine for surfing the internet and watching films. If the latop is a desktop replacement you should just get him a cheap PC. Anything like a cheap 2200G with 8GB RAM and a small HD will do just fine. If it does have to be a laptop as it needs to be portable then an older machine will be more than enough.
Reactions: hucklebuck
Thanks everybody. He got a Dell with an i5. I have heard that currently intel is better to go with for linux?
That hasn't been true for 10 years. Linux runs perfectly on AMD as well.
· Vermin Supreme 2020
i'd grab a used lenovo from Ebay. T440-T550, and a small SSD = win.
though that $200 ryzen laptop advertised on the front page would probably be great as well.
· Overclocker
Since this is not 2009 or earlier you are fine with almost any laptop. Back then you had to be cautious because some WiFi cards were not supported at all etc. At least when it came to the more interesting use cases of WiFi, maybe the basic user functionality worked but you couldn't do advanced stuff.
OS doesn't care what CPU or GPU etc. you have. Sure some odd configurations such as multiple NUMA nodes are better supported on some Linux than on some Windows variants because of focus more on servers, but for surfing web and regular parts, it doesn't freakin' matter.
For the web and videos even a phone has the needed functionality and performance nowadays for common users, just the screen size is small.
1 - 10 of 10 Posts
