1 - 3 of 3 Posts
hi guys im doing a budget build for gaming and 3d reindering at 1st i was gonna get a fx 6300 now getting a i5 4460 but trying figure out which motherboard im not the best with this stuff also does it matter which brand it is? so the two mobo are h81 and b85
Intel H81 Chipset or Intel B85 Chipset
the B85 is $39 extra is it worth it or not much difference?
gaming and 3d rendering setup
and can any graphics car fit in these boards i dunno too much bout this thanks guys im new here too so hi:)
Any graphics card can fit in those boards, the difference between B85 & H81 is that B85 has more usb3.0 ports, more sata 3, and pcie 3.0 while the H81 supports pcie 2.0. If these features are worth the extra cost, its up to you.
1 - 3 of 3 Posts
