1 - 7 of 7 Posts
I've finally figured out how to post after several days. Great site here.
I'm stuck on ASUS boards P4P800-E, P4P800S (& S-X), P4S800 ETC...
Will a P4 2.4A perform oc to the equal of a stock P4 3.0?
Should I oc or get the larger CPU?
Thanks
your mobo is awsum! u dont need to change it!
that cpu is one of the best OCing processors out there. u can get better peerformance OCing it then just buying a 3ghz. but u need good cooling and good ram! o yeah and WELCOME
Just a question since I'm getting something like that.. you talking about the 2.4, 533mhz fsb, 1MB cache right?
Discussion Starter · #6 ·
My daughter wants a new computer, and I'm on a budget. I'd like to save money by oc'ing a new P4 2.4A, but need to know if cooling and a power supply are going to raise the price to the level where i might be better off purchasing a P4 3.0 +-.
Water cooling is out of the question. Is cheap air cooling possible for 2.4A?
Correct. Cheap at Newegg. I'm not sure if I'm ordering it yet, trying to get a budget build feedback.
1 - 7 of 7 Posts
