Which mobo
426 Views 12 Replies 7 Participants Last post by  Skullzaflare
im looking at 3 mobo's
P7N SLI Platinum 750i
for 130
MSI P45 Neo-F
for 85
or
MSI P43 Neo3-F
for 75
which should i get? i have less than 30 minutes to decide
1 - 13 of 13 Posts
Gigabyte EP45-UD3P?
I'd probably take the P45 Neo-F, but then again I would never buy an MSI board.
Get the Neo-F -- just cuz I despise nvidia chipsets -- (I know, I have one
), unless SLI is a priority.
well, i should have stated
i want the board that will overclock a quad best
In order to OC well, you need a board liked Gigabyte EP45-UD3R/3P, it is from $99 to $115 on egg and well worthy.
Then go with the Gigabyte UD3P or UD3R depending on your price range.
Originally Posted by linskingdom
In order to OC well, you need a board liked Gigabyte EP45-UD3P, it is $115 on egg and well worthy.
im looking at instore pickup
also looking at the only pic, im thinking my v8 wont fit the ud3p/r
also, im on microcenter
($144)
Honestly, I think all those are a waste of your time.
($144)
Then I go with MSI P45 Neo-F in your list but quad OC will be limited.
vs the mobo im running that doesnt overclock 1fsb?
Why pick out MSI? Why not pick out a good brand.
P7N SLI Platinum 750i or a dfi lanparty i like the nvida chipsets and for a little bit more that you one mobo choice you can get the evga 780i mobo 170 or 150 after rebate
http://www.newegg.com/Product/Produc...82E16813188043
as i said, im looking at instore pickup at microcenter
1 - 13 of 13 Posts
