Which mobos support Preslers?
356 Views 6 Replies 5 Participants Last post by  wowza
What intel motherboards support the new preslers? That is also on sale at newegg? Also which presler cpu is the most worth it? Price and performance wise? Thanks for the help
1 - 7 of 7 Posts
945 and 955 chipsets support Preslers. I have only seen a few examples, but it seems like the 920 is doing pretty darned well, I have seen 4+ghz on air from a couple guys.
The 975x chipset supports Preslers as well.
Yeah, that one too.
Thanks guys! anymore? also how well are they at oc'ing on air? and which mobo should I get?
I'll post the results of my build probably next week. I hope. The build was supposed to be done on Saturday, but ran into the problem of being shy one standoff, and just too busy last 2 days to finish it (Do NOT rush a build, LOL), and I want to allow the system to settle before throwing it through it's paces.
When did Radio Shack stop being usefull? Or is it just mine that only sells radio controled cars, TV remotes and cell phones?
ANYWAY, I got the 920 cause I was on a budget, and I heard lots of good things. I haven't seen any 4Ghz air results, but I heard is was almost a standard on water cooling, with mid to high 3s well known on air. I got mine on Newegg for $269........
Err.. The Asus P5P800-SE with the springdale 865PE chipset can support the presler too (with a new bios flash) here is the official Asus list of supported processors for the P5P800-SE board.
1 - 7 of 7 Posts
