Which Monitor Is better?
366 Views 9 Replies 7 Participants Last post by  Re-Evolution
i keep struggling on which monitor to get for gaming
http://www.ncixus.com/products/?sku=...g&promoid=1066
or
http://www.newegg.com/Product/Produc...82E16824009162
which one guys?
1 - 10 of 10 Posts
The Samsung has the better response time making it better for gaming and they also have a better reputation IMHO. I have always used Samsung LCDs and never a problem, never a single dead pixel as far as that goes.
anymore more suggestions instead of just one person?
I would go with the Samsung. What is your budget?
I'd go with the Acer, it has a larger resolution.
Personally I'd go with the Samsung. Zero dead or stuck pixel warranty, exceptional picture for TN panels imo also.
but the acer has a higher resolution?
or is the samsung that good to sacafrice to a 1680x1050?
Another vote for the samsung, as its only a inch smaller. The quality out weighs that :thumbs:
Unless you have a very high end gfx setup you more than likely won't be able game smoothly at 1920 x 1080 with newer games so that is irrelevant.
The quality is worth the sacrifice IMHO.
1 - 10 of 10 Posts
