1 - 4 of 4 Posts
I am in the process of designing and building a system for a friend.
He is is a Audio enthusiast but will also be installing and running VMware vSphere. (He wants 32 gigs of ram to run multiple VMs.)
Currently we just need to pick out the Motherboard and RAM.
Does anyone have any suggestions for this build?
Any and all other suggestions or comments, regarding the build, are welcome
Current Build
Audio Interface (Already Owned)
External MOTU 896MK3
Firewire PCIE Adapter ($25)
SYBA 2-port of 1394b + 1-port of 1394a Firewire Ports PCI-Express Controller Card (SY-PEX30016)
Any Suggestions?
These are some boards we were looking at.
GIGABYTE G1 Gaming GA-Z170X-Gaming 7 (rev. 1.0) LGA 1151 Intel Z170 HDMI SATA 6Gb/s USB 3.1 USB 3.0 ATX Intel Motherboard
MSI MSI Gaming Z170A GAMING M5 LGA 1151 Intel Z170 HDMI SATA 6Gb/s USB 3.1 ATX Intel Motherboard
Processor
Intel Core i7-6700K 4.0GHz Quad-Core Processor ($350)
Processor Cooler
Cryorig H7($35)
or
Noctua NH-14($73)
or
Coolermaster Hyper 212 ($75)
Will have to figure out which one of these firs, especially if the RAM has cooling fins.
32 Gigabytes of RAM
Any Suggestions?
Videocard
EVGA GeForce GTX 970 4GB GAMING ACX 2.0 04G-P4-2972-KR ($340)
Hard Drives
1x SAMSUNG 850 EVO 1TB ($350)
1x BYTECC Bracket-35225 2.5" HDD/SSD Mounting Kit For 3.5" Drive Bay or Enclosure ($36)
1x WD Black 1TB 7200 RPM SATA 6 Gb/s 64MB Cache 3.5 Inch - WD1003FZEX($75)
CD/DVD Drive Burner($30)
1x Plextor 24X SATA DVD/RW Dual Layer Burner Drive Writer - Black Optical Drives PX-891SAF
Power Supply ($200)
CORSAIR AXi series AX860i 860W
Case($149)
Cooler Master HAF 932 Advanced
Originally Posted by Crazy9000 View Post
Just going to throw this out there, but has he considered using a separate PC for the VM's? Then he can concentrate on a pure gaming/audio setup for the main rig.
You can get a server meant to run a bunch of VM's for around $200: http://www.ebay.com/itm/Dell-PowerEdge-R610-Virtualization-Server-E5620-2-4GHz-8-CORES-32GB-2x-146GB-/371611054945?hash=item5685beb361
That was the first thing I suggested, but he wanted it all on the same desktop computer.
(In fact I personally just purchased a server for VMs.)
Discussion Starter #4
I updated the original post with two motherboards we were looking at.
What do you think of these choices?
1 - 4 of 4 Posts
