1 - 4 of 4 Posts
· Silicone Overload
I'm currently using my sig rig, and I'm looking to upgrade my system over the course of the summer.
I want to purchase a 2500K, but I have no clue what motherboard would be right for me. I've heard good things about the Asus P8P67 Deluxe, but it seems a bit overkill to buy a board that costs more than the processor. I will probably only overclock it to 4.5GHz, and I don't ever plan on having a need for more than 2 cards in SLI (I prefer 1 card). Which motherboards would best suit me?
Also, I'm thinking about upgrading my GFX card. Is Kepler going to come by the end of the year, or should I pick up a GTX 480 for $240 while it's still on sale at TigerDirect?
Thanks much!
I recommend the Asus P8P67 Pro and the Gigabyte UD4. You can also research the ASRock Extreme4...these are all good boards, ultimately you have to decide which one you like best. As for Kepler I think you probably have as good of an idea as anyone here unless there's an Nvidia rep and he's not going to tell.
I'd say if you want to upgrade your card you should because new tech release dates are always subject to change.
Reactions: Mithrandir8
1 - 4 of 4 Posts
