Originally Posted by
Ashbury
Not at all. It plugs into something. Literally. You remove three screws, pull the mouse apart, unplug the existing cord, plug in the new one, screw the mouse back together. Done. CeeSA will make sure you have the right plug already on his cord if you tell him what mouse you are buying the cord for when you order it from him.
To be honest, the hardest part by far is carefully removing two of the mouse skates that cover two of the screws and then putting them back on. Once hyperglide and other companies make replacement skates for the pro, you can skip this step and just rip off the skates and replace them with new skates. For now, I wanted to put the old skates back on so had to spend about 15 minutes carefully removing them. Replacing the cord took about two to three minutes not counting the time it took to remove the skates.
Edit: make sure you have a tiny screw driver for the pro - even a "0" is too large - need 00 or 000.
