For the RX360 which nozzle should I go? I want a compression fitting
Bitspower compression fitting 1/2ID 3/4OD $18.99 (a little expensive)
Pair G1/4 Compression [13mm, 1/2"] NZL-V13KG $10 (cheaper but will it fit 1/2ID 3/4OD tubing?)
