1 - 14 of 14 Posts
9800GT 1GB $140
Core Clock- 600MHz
Stream Processors- 112
Memory Clock- 1800MHz
Memory Interface- 224-Bit GDDR3
http://www.newegg.com/Product/Produc...82E16814130440
260GTX 896MB $215
Core Clock- 576MHz
Stream Processors- 216
Memory Clock- 1998MHz
Memory Interface- 448-Bit GDDR3
http://www.newegg.com/Product/Produc...-434-_-Product
Now my question is, which would i be better off getting for my sig rig?
Keep in mind I'm not going ATI, if you have any reccomendations, that are other nvidia cards I'll consider my price range is under 200$.
Laptop Enthusiast
Originally Posted by Brian_
9800GT 1GB $140
Core Clock- 600MHz
260GTX 896MB $215
Core Clock- 576MHz
Keep in mind I'm not going ATI, if you have any recommendations, that are other Nvidia cards I'll consider my price range is under 200$.
Okay... for starters, the 9800GT is a re-branded 8800GT and the 9800GT has a 256-bit bus, not 224-bit bus. 224-bit doesn't exist.
Lastly, get a used GTX260. It's plenty powerful for whatever you want to do.
1 - 14 of 14 Posts
