1 - 12 of 12 Posts
Corsair Ax850 $183
7yr warranty
1-12V rail
4 PCI-E connectors
Seasonic X-850 $195
5yr warranty
1-12V rail
4 PCI-E connectors
Enermax MODU87+900W $240
5yr warranty
4-12V rails
6 PCI-E connectors
I'm looking to replace my tx950 with something modular and high efficiency to clean up the wires in my case. I will be looking into another water cooled 480 for sli in the near future along with a second mcp355.
Which one would you go for?
It seems like a toss up, though I'm not sure the Enermax is enough better to justify the cost difference (I won't need 6 PCI-E connectors).
The AX850 and Seasonic X-850 are on the same platform, so get whichever is cheaper. They're both better than the Enermax.
· Premium Member
Lepa g900 same as the enermax but cheaper then the x and ax 850 the nzxt hale 850 also another great option
I'm more partial to silverstone myself but since there both essentially the same and corsair offers 2 additional years why not.
Discussion Starter · #11 ·
So the consesnsus seems to be the ax850. The 7yr warranty is looking good.
Does it have the best ripple suppression/stable voltage of the 3? I know they are all stellar, but I figure since I'm in the 200 ballpark, I may as well get the best power supply, and not the most popular or cheapest. 20 bucks is the least of my concerns.
1 - 12 of 12 Posts
