1 - 12 of 12 Posts
Which is my cpu temp because I was playing AO and well my comp froze then it my moniter said not display found, like I didn't have the cable plugged in. I turned it on and it was fine but I am worried.
my temps
my temps
i can't see the links ... or the temps can you post the numbers
Ummm It's like a full screen pic in the post, it's alos in the quote you made.
can't see it tho ... won't display at least for me
my temps
If your folding with that rig, then turn on your temp monitor then either turn on or off folding, you will see a big drop or gain, then that is your cpu temp.
Discussion Starter · #6 ·
Hmmm, my video card temps are high too and ati tool is saying that I have a 44-47c ambient temp which I am wondering why is it soo high. It did lower after Ii had put the side back on though. I figured out that it is temp#1, and the idle and load temp has gone up slightly. Load has gone from 40c to 42c, and idle from 34c to 37c. Also my video car is getting a little to hot.
Those are still good temps.
lol i cant see the pic either... its the lil white box with an "x" in the middle... but ya do what jrabb said... or get everest and compare the temps....
Discussion Starter · #9 ·
Hmmm, are you sure that those abient temps are of because I wuld say it is a LITTLE warm in my room but it may because my left leg is right by the comp. Als o playing nfs most wanted I see my x800xl on STOCK speeds hit 70c which it haden't done before with it oc'd.
My temps again: http://img513.imageshack.us/img513/7385/temps1pm.jpg
This is after playing a litle free roam in mfs: MW
i dont think your leg would have much effect on the pc temp, but a warm room will... maybe turn the heat down a few degrees or just close some vents in your room...
Discussion Starter · #11 ·
I didn't mean my leg would affect the temp I ment that the comp may be heating me and making me make a bias judgement. I am gonna try and open up the windows since I don't have the heat on.
1 - 12 of 12 Posts
