1 - 11 of 11 Posts
<img src="/images/smilies/confused.gif" border="0" alt="" title="Confused" class="inlineimg" /> I'm using SpeedFan software to monitor my temps...but not able to tell which on is the cpu temp. Which one is it? I have attached a pic.<br><a href="http://assets.overclock.net.s3.amazonaws.com/4/4e/4e62b83d_vbattach34178.jpeg"><img src="http://www.overclock.net/image/id/616304/width/525/height/525/flags/LL"></a>
Hey they have a Speed-fan FAQ that tells you how to read all that..I looked and couldn't find it.. Go look around in the FAQ section....
I took an average of all those temps and it came to about 27 Degrees, which sounds about right....<br />
<br />
I know this really doesn't help, but it will at least this thread back to the top for someone smarter than me <img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" />
Hi,<br />
<br />
Use <a href="http://www.xtremesystems.org/forums/showthread.php?t=103638" target="_blank">Core Temp</a> to watch your temps! Its better than speedfan and it runs in background ...
Reactions: gonX
temp 1...but there are two *scratches head*<br />
<br />
EDIT: you can register the mobo online and it shoukd pick the proper names up for you, i think gonX did an FAQ on it!
Discussion Starter #6
<tr>
<div>
Originally Posted by <strong>Sin100</strong>
<a href="showthread.php?s=5f012238fa36186cbb85825ea8d4fba8&p=1385934#post1385934" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">temp 1...but there are two *scratches head*<br />
<br />
EDIT: you can register the mobo online and it shoukd pick the proper names up for you, i think gonX did an FAQ on it!</div>
</td>
</tr>
</table>
</div>then what is the, core temp?
i would say its more likely the bottom temp 1 considering your cpu fan is on 67%.<br />
<br />
But please don't take my word for it!
<tr>
<div>
Originally Posted by <strong>The Specialist</strong>
<a href="showthread.php?s=5f012238fa36186cbb85825ea8d4fba8&p=1385919#post1385919" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">Hi,<br />
<br />
Use <a href="http://www.xtremesystems.org/forums/showthread.php?t=103638" target="_blank">Core Temp</a> to watch your temps! Its better than speedfan and it runs in background ...</div>
</td>
</tr>
</table>
</div>QFT
If you have probe opened and check.You see the cpu temp and compare.In speefan 4.30 is the 1st one.<br><a href="http://assets.overclock.net.s3.amazonaws.com/c/cf/cf052a94_vbattach34221.jpeg"><img src="http://www.overclock.net/image/id/616272/width/525/height/525/flags/LL"></a>
It is Temp 2. I have used speedfan on more than 15 boards and when it displays 3 temp numbers, I have noticed that it detects chipset temp, proc temp and acpi temp in this particular manner. check with core temp to confirm<img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb">
put CPU under 100% load and see which temp rises quickest
1 - 11 of 11 Posts
