1 - 9 of 9 Posts
Danger Den MC-TDX for AMD AM2 CPU/Boards
VS
Watercool HEATKILLER® CPU Rev3.0 754/939/AM2 LT CPU Water Block
VS
Swiftech APOGEE GTZ Ultra Extreme Performance Universal Water-block
I believe the Heatkiller 3.0 beats the Apogee GTZ, but I don't know about the Danger Den. How about the Apogee XT? It beats the Heatkiller.
Originally Posted by firestormcomputers
This is better than all of them.
http://www.sidewindercomputers.com/swapxtcpuwa.html
And the EK Supreme HF beats out the Apogee XT for temps and flow rate across the board, but I have no idea what sockets are supported for it right now.
As for the MC-TDX -- I've got one. It's good but it's nothing special.
Yeah, if you're looking for a really awesome block, the Apogee XT or the EK Supreme HF are the blocks to check out.
Originally Posted by rickyman0319
EK Supreme HF , there is different kind of metal.
nickel
Acetal
nickel + acetal
which one is better?
I honestly don't believe the top plate will make any difference.
You can check out this review, though. the EK Supreme HF comes with a set of different jet plates that yield different flow rates and temp results. Using the right one is important to getting the most out of it. The review provides results for each of the jet plates, so you'll be able to figure out which you want to use.
i think after one of the reviews ek said they will ship the blocks with the plate #1 as that yielded the best results.
1 - 9 of 9 Posts
