is this for the commando the nbmax is for the rfII style boards
Originally Posted by shedokan ![]() I won't order only chipset cooling from another store, That's why I asked from sidewinder only. What about this one? http://www.sidewindercomputers.com/enwmnpfocomo.html |
Originally Posted by shedokan ![]() What's the capacity of Swiftech MCRES Micro Revision 2 reservoir by the way? (ML) I can get the MCW30 in israel for 55$ dunno if It's worth it. |
Originally Posted by shedokan ![]() kk, I gotta think about the NB cooling if It's worth for me. Besides, http://www.sidewindercomputers.com/t...-radi1203.html Should I get it for my rad? I'd like to hear people expriences with/without shrouds.. Will it reduce my temps * noise(most important thing)? I will be using Panaflo 120x38 1700RPM. |
Originally Posted by go4life ![]() I would go for the Panaflo's if I where you, its better to have some static pressure and good airflow. If you think 30db is to much, get a fancontroller later ![]() |
Originally Posted by shedokan ![]() I've got a MFC1 Zalman fan controller uhm okay. Someone told me that with 120x38mm fans I will really need shrouds, is it really nescessary? |
