1 - 13 of 13 Posts
Efficiencycionado
toliman of course. and oc it to 2.6+
the 7750 will clock at higher speeds so it would do better in gaming. but not for long since most future games will be programmed with lotsa threads.
If he can clock the both the same, the X3. Otherwise, go with the X2.
well id imagine i could get the kuma to 3.1 to 3.2 and the toilman to 2.4 to 2.6 and also if i got a motherboard with only 1000mhz hyper transport instead of 2600mhz will it affect my performance at all?
It may not be really noticeable, but you will be taking a performance hit. It may be more significant while benchmarking though.
And I'd probably get the 7750 in that case. If he can afford it, I'd recommend the 45nm 710/720 X3's. Great processors for the price.
Reactions: richardshewfelt
Efficiencycionado
3rd
Efficiencycionado
yes you can!
just update the bios
Originally Posted by SinX7
Wait, nvm the X3 710 phm is AM3
You can put an AM3 CPU in an AM2/AM2+ socket motherboard.
OP, I would go with the X3 8450.
Discussion Starter · #13 ·
heres the final build
any changes ? his max is $420
Rosewill R5717-P SL
http://www.newegg.com/Product/Produc...82E16811147057
Foxconn A7VMX-K AM2+/AM2 AMD 780V Micro ATX AMD Motherboard
http://www.newegg.com/Product/Produc...82E16813186143
POWERCOLOR AX4830 512MD3-H Radeon HD 4830 512MB 256-bit GDDR3 PCI Express 2.0 x16
http://www.newegg.com/Product/Produc...82E16814131129
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066
http://www.newegg.com/Product/Produc...82E16820231226
Rosewill RH-40C 3.5mm Circumaural Multimedia Stereo Headset
http://www.newegg.com/Product/Produc...82E16826193029
Cyber Acoustics CA3090WB 7 Watts total RMS 2.1 Black Gaming Speaker
http://www.newegg.com/Product/Produc...82E16836150043
AMD Phenom 8450 Toliman 2.1GHz Socket AM2+ 95W Triple-Core Processor
http://www.newegg.com/Product/Produc...82E16819103254
Western Digital Caviar RE WD2500YD 250GB 7200 RPM SATA 3.0Gb/s Hard Drive
http://www.newegg.com/Product/Produc...82E16822136010
hec Orion XPOWER585 585W ATX12V 2.01 Power Supply
http://www.newegg.com/Product/Produc...82E16817339001
1 - 13 of 13 Posts
