1 - 9 of 9 Posts
of those 2 I'd buy the ATI card. But personally, for the money I'd probably get a 6600gt. Just my opinion.
Have you thought about othercards or not.
If i had to choose one of them. Then i'd go with the cheaper 1 becuase they'll both have the same performance. Nothing varies between the 2 brands besides how well they've put the card together and the software package it comes with, that's all. But if your spending that much. I would spend the extra few bucks and get the all in wonder 9800 pro. That come with VIVO and TV tuner which would ussually cost and extra $100. Go with that if you want a 9800 pro (i saw this at new egg). find some info out on dual SLI 6200's. But if i was buying a card for about $200 i would get the 9800XT over the 6600GT. So the 9800XT all in wnder for $230 is the go. You can play all your games while recording your favourite TV shows. It's excellent for $230. Buy that one.
lol ***....there is no 9800xt all in wonder...geez. and he cant run 6200 in sli, he DUSSNT have it. stop smoky that weed.
of those 2 the performance will be the same, just looks at what color the card is and the bundled software. but a way better deal would be a nvidia 6600gt, which is much better and around the same price
no, From XFX, the minumum is 300w. It wont run the best, but it will run on 320 W but in the future, try to upgrade to a 420 or something down the road. ( but It will run). I almsot got the 9800PRO and glad I didnt. Dont ge tthe 9800PRO, get the 6600GT and good luck. What resolutions do u run at? If under 1600 then the 6600gt is fine, if 1600 and up, 256MB card. like a 9800XT.
1 - 9 of 9 Posts
