Which Power Supply?
282 Views 4 Replies 4 Participants Last post by  ryan]
http://www.newegg.com/Product/Produc...82E16817256020
or
http://www.tigerdirect.com/applicati...989&CatId=2535
both are about the same price after rebate. which one would you guys recommend?
1 - 5 of 5 Posts
I like the silverstone best, but either is good and both are way, way overkill for your sig rig
Definitely the Silverstone. Not only is it better, but you can get it from Newegg!
lol yea, those are overkill, unless youre planning to buy some power hungry gfx cards or upgrading your rig altogether.
im content with my 750w
either way, both are pretty good
well i'm doing some upgrades and while i have the money i just want to future proof my power supply.
on the way i have:
-i7 920
-p6t deluxe
-corsair ddr3 1600
-another wd 500aaks for raid0
-and im still deciding if i want 2x gtx 285s or a gtx295
1 - 5 of 5 Posts
