1 - 20 of 67 Posts
i have just had the opertunity to upgrade my system and i have almost decided on the hardware which i will buy
, but i am still wondering which processor would be the best to get, i will be gettin a 939 socket but which one i dont no as yet,
http://www.overclockers.co.uk/acatalog/AMD_CPUs.html
it will definatly be one of those apart from sempron lol, advice on which one will be greatly appriciated
other component which i am getting is...
http://www.overclockers.co.uk/acatalog/Socket_939.html :the top one
and;
http://www.overclockers.co.uk/acatal...agx_2d048_2dpc
the powercolor x1800xt 512mb
Discussion Starter #2
any ideas, do you think dual core is the way to go or what do you think, please give me some input
I presume by the X1800 this is going to be a mainly gaming rig?
When do you see your next upgrade after this one?
and;
hmm for single core you could get the 3700+ or if you can find optys either the 148 or 150
but if you want Dual core the 4400+ or the opty 170 //175
please post you're budget
Discussion Starter #5
my budget is about £350 for cpu, my next upgrade wil be next month as it is my birthday and i should have money for then
With the X1800XT costing £279.95 from the site you're using, your only left with £70.05/$120 (USD). But the mobo costs you £129.95; so you need more before we can help really. But unless you're really just trying to go top of the line, their is no real reason for gaming to get anything more than a AMD64 Athlon 3700+. I currently use an AMD64 3200+ Venice and run all my games with the highest resolution that doesn't look funny, and the highest graphics without lag (and I'm only using a 6600GT with a Shadow Card). Im running HL2:CSS, BF:2, and NFS:MW. If the £350 is JUST for the CPU then go with a AMD Opteron 175 Denmark 1GHz FSB 2MB L2 Cache Socket 939 Dual Core Processor (if you're not worried about spending all the money.)
http://www.newegg.com/Product/Produc...82E16819103584
Discussion Starter #10
well i would like to get a top end CPU as i want the best bang for my buck lol, but im not sure if dual core is the way to go or not, also do u no if the mobo i have chosen is compatible with the dual core
http://www.newegg.com/Product/Produc...Desc=Crossfire
Use that for specs, it's better detailed. Yes it has dual cored support. And the opteron I showed you is DEFINENTALLY the best bang for your bucks. The next up from it is in the $700's ($602 was your limit.)
Discussion Starter #12
ok soo if i get that operton instead of the 4400+ x2 what is the main difference? apart from the operton is a better overclocker
They're cheaper and clock better than the parts that are priced higher than them, AMD got smart and discontinued them, so get one soon if you're getting it. They run smoothe as buns and stay at cool temps.
Discussion Starter #14
well i have found out that they have an extra 1mb cache but run at the same speed as the 4400+x2, hmm to me AMD seem to have made a big mistake really by makin 2 processors almost identical but the better one being cheaper. soo if i were to get an operton 175, the dfi mobo and the x1800xt 512mb will these 3 component run well with my other components in my comp?
Like cake and icing. Did I help?
Discussion Starter #16
sure did now i just need to find some place in england that has the cpu in stock this could be a challenge, if i cant get one do u think there will be much difference between a opteron and 4400+x2?
Nah, they both rock! Just go with the opty if you can!
Discussion Starter #19
well i have been looking into gettin the opty and have found it very difficult to find them in UK, but i have found one seller
, but i have heard from a friend that i will need registered RAM, is this true because if not i will have to spend more money
1 - 20 of 67 Posts
