1 - 13 of 13 Posts
Hi.
I bought a new comp 2,3 months ago. I want to test do all works perfect and to see will i get adequately and max results for those components.
phenom II x4 925
ATI radeon 5770 sapphire
770-C45
4Gb RAM DDR3
WD3200AAKS and Samsung 500Gb F3
And i use WIN 7 x64.
· I'm NOT new to Overclock
Just to add to the above. Memtest for any memory overclocking. Also Furmark and 3dmark for scores
For now i would like to test will i get maximum score for my PC then i will test stability. How i see those programs are for stability, right?
I will download furmark and 3d mark. 3d mark from which year to download? Do these to programs test HDD too?
You need HDTune for your hard drive.
06 should be fine.... And furmark FTW
Discussion Starter · #8 ·
Ok, here are the 1st results. Please, i would like someone tell me are these results are very well for my PC.
Results from HD Tech:
WD3200AAKS
Samsung 500Gb F3
And there is a problem
. I installed 3DMark Vantage. I ran it then "Run Benchmark" and there was only the black screen and nothing happen. I wait several min. Then i try ctrl+alt+del and nothing happen. Then i restarted and tried again, i get the same problem. Then i ran FurMark_v1.8.0 too. I didn't not post the results (i will later) because when i tried to ran in full screen i got black screen here too
. It is only work in window mode. Why is this happen?
1 - 13 of 13 Posts
