Which one would you buy?
  • Silverstone ST85F-P
    Votes: 3 8.8%
  • NZXT HALE90-850-M
    Votes: 3 8.8%
  • Corsair AX850
    Votes: 24 70.6%
  • XFX XPS-850W-BES
    Votes: 2 5.9%
  • Silverstone ST85F-G
    Votes: 1 2.9%
  • None of the Above, please specify in a post!
    Votes: 1 2.9%
1 - 20 of 25 Posts
VeeDub Enthusiast
rig is in my signature, i will add a second optical drive and a SSD maybe a third hdd. thats all the upgrades ill be doing, i came up with 840w MAX wattage with everything connected and maxed out as i like to have a stable and head room psu, one of my requirements was dual EPS headers as my Board has 2x 8 pin cpu power..., also i might remove the watercooling loop within the next 3 month, and possibly add a 970 or 980x.
Heres what i could come up with after doing a few days worth of research, check the poll, and if you want, leave some comments as to why which what where psu to pick...
heres a shortcut to a comparison within newegg of all 5 power supplies next to each other:
Comparison link
Comparison link
I'm looking to buy the Corsair AX-850.. so get that one ;D
Seen some videos of it on YT and read up on it.. looks to be the best on that list If I'm honest.. Also the Corsair brand name is no match for the other contenders. (Says me with my little Chieftec
All of them are fantastic. All have pros and cons against them. A lot of people will say the AX850, since it's based on SeaSonic's X platform; but at 850W+ that platform isn't all that much better than the M12D platform (used in the XFX) or the CWT DSG platform (used in the HX850) or the Superflower Golden Green platform (used in the NZXT and Kingwin LZG).
The Silverstone -P unit is a bit lower end than the others, but not so much so you'd see the difference. The Silverstone -G unit is based on an untested platform, but it's probably up there with the others or not far behind.
The AX850 powers up my system and has a lot of left over power to spare, this is my 2nd Corsair powersupply and it's been running fine for 2 months so far. I had to deal with Corsair's RMA supprt once for a pair of memory sticks and it was an easy process.
Those PSUs are all great but I fail to see why you need a 850W unit... you'd be fine on a good 550W unit, if you wanted lots of room you could get a 650W and be set... Even if you added a 2nd 6970 you'd still be fine.
VeeDub Enthusiast
Discussion Starter · #13 ·
Originally Posted by Shub
Yeah... with the above screenshot in mind, this further consolidates my opinion that even the best PSU calculator out there (the one you used) is crap. 844W is ludicrous for your setup.
any better recommendations ? my ears are yours, i ve used that one since its been available and have not had a bad call so far
A 980X at 5.1GHz? Come on, man.
Also, you don't use 100% TDP or 100% load, you have to go by 90% unless you know what you're doing.
VeeDub Enthusiast
Discussion Starter · #17 ·
point 1 taken, idk how high ill be able to get it, but it ll be around the 5+ ghz marks
with what i will be picking up 1st week in february in ATL xD
100%tdp, just to make sure i have some headroom you know, should i settle for a smaller psu then the units i picked ? if so, which wattage would you recommend, keep in mind i want dual eps headers as a minimum on the psu
Forget the goddamn word headroom, christ if I had a nickel for every time someone said that as an excuse for wasting money with flimsy justification... I'd have a lot of spare change.
Don't touch the TDP settings on that calculator.
And you're not going to be able to do 5GHz 24/7 with a 980X. Try 4.5GHz max.
A quality 750W would run your system with Crossfire.
Reactions: hitman1985
The Silverstone gold also looks like an enhance unit, as are the rest of the Silverstone units so far.
I voted for the XFX modular, but the Corsair AX and Seasonic X are both great units as well.
1 - 20 of 25 Posts
