1 - 5 of 5 Posts
Originally Posted by MLJS54 View Post
Hell OCN,
I'm deciding on which GPU to put in my new build until Polaris comes out, and am thinking of getting the 8GB Sapphire R9 390. I will be gaming in 1440p on the ASUS MG279Q (1440p; Freesync; 35-90 range) so am liking the fact that the card has 8GB of RAM and also will support Freesync. What are your thoughts on this card?
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202164&cm_re=sapphire_r9_390-_-14-202-164-_-Product
That brand is one of the best 390. With a free game it might be worth it even if Polaris is coming soon.
Op in this thread talks a little about each brand . . .
http://www.overclock.net/t/1561704/official-amd-r9-390-390x-owners-club
Discussion Starter #4
Originally Posted by iinversion View Post
I think if you are going to get a GPU to have until Polaris comes out, as you put it, then you should not buy a new card.
Find a used 290/290X for around ~$200.
Isn't $200 for a 290x a long shot? I seen them go for $250-300 still, depending on the brand.
...when you walked in
I picked up a 290X for $200 just last week. If you don't look on eBay then you can find them on forum marketplaces such as this or reddit's hardwareswap
1 - 5 of 5 Posts
