1 - 5 of 5 Posts
i'm wondering how many raid setups there r and wat each one does and wat there advantages r over the other
Not that I condone wiki as a source for all info, but its fairly detailed.<br />
<br />
<a href="http://en.wikipedia.org/wiki/Redundant_array_of_independent_disks" target="_blank">http://en.wikipedia.org/wiki/Redunda...ependent_disks</a><br />
<br />
And to answer the advantages questions, it depends on what you want to do with it.
well i heard that having drives in a raid setup increases performance in terms of read and write speed. is that true?
yeah basically do you want speed or a redundency or a middle of the road, i personally like raid 0 which uses atleast 2 hdds and is pretty fast but if you lose one disc you lose the array<br />
<br />
and yes thats true you will get much fasster speds ina raid 0
Discussion Starter #5
well i guess speed the most, but also alot of storage. is it possible to run my o/s on say like a 36gb raptor then have an array for mass storage
1 - 5 of 5 Posts
