Originally Posted by steveo420 Id say a heat spreader. If the sinks were better companies like ocz would have it. |
Originally Posted by shermstix I use heat spreaders, but memory doesn't really get that hot to begin with. If you have good case flow and add a heat spreader, you will never have issues. |
Originally Posted by steveo420 I thought ram didnt get very hot. All you need is good airflow in your case. |
Originally Posted by wrbsti i dont have a case and my basements cold so ambient temps down here are very nice. but yet i believe ram does get somewhat hot. nothing to perhaps worry about but i wouldnt mind removing the platinum plates and installing some thermal goo. |
