1 - 20 of 27 Posts
Hey there.<br />
<br />
Which RAM would you recommend for overclocking the e6600 with the asus <br />
p5w deluxe? I need 2*1gb RAM ...<br />
<br />
I was looking at the <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16820227091" target="_blank">http://www.newegg.com/Product/Produc...82E16820227091</a> OR <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16820145033" target="_blank">http://www.newegg.com/Product/Produc...82E16820145033</a><br />
<br />
Maybe it would be better to go w/ ddr2 800 ? Thanks
Crucial Technology 2GB $230<br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16820148017" target="_blank">http://www.newegg.com/Product/Produc...82E16820148017</a>
Discussion Starter #4
Thanks for the quick reply. Since I dont want to start another thread... I already have a 520W OCZ Powerstream PSU from my other PC that I can use. Do you think it would be sufficient or should i go w/ something like the OCZ 700w GameXStream ??
<tr>
<div>
Originally Posted by <strong>OCnub</strong>
<a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1398454#post1398454" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">Thanks for the quick reply. Since I dont want to start another thread... I already have a 520W OCZ Powerstream PSU from my other PC that I can use. Do you think it would be sufficient or should i go w/ something like the OCZ 700w GameXStream ??</div>
</td>
</tr>
</table>
</div>The powerstream is more than enough, even with a 8800GTX
<tr>
<div>
Originally Posted by <strong>boredom</strong>
<a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1398460#post1398460" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">The powerstream is more than enough, even with a 8800GTX</div>
</td>
</tr>
</table>
</div>Agreed.
Discussion Starter #7
Thanks for your help.. I will most likely go for the Corsair XMS2 and keep the Powerstream <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
<tr>
<div>
<a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1398467#post1398467" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">Thanks for your help.. I will most likely go for the Corsair XMS2 and keep the Powerstream <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /></div>
</td>
</tr>
</table>
</div>Do NOT get the XMS2, you would be paying more for same, or less if you end up the batch with Promos chips<br />
<br />
The Crucial sticks I posted use D9GMH chips while being $140 cheaper
If you're looking for the best DDR2 you can get for your Conroe system, it's this stuff:<a href="http://www.tankguys.biz/ddr2-3338-p-1692.html" target="_blank">http://www.tankguys.biz/ddr2-3338-p-1692.html</a><br />
<br />
For the best deal on good overclocking DDR2 for Conroe, I'm gonna agree with boredom. That Crucial Anniversary RAM is excellent, and has easily hit 1000+ MHz at good timings.
<tr>
<div>
Originally Posted by <strong>Witchfire</strong>
<a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1398507#post1398507" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">If you're looking for the best DDR2 you can get for your Conroe system, it's this stuff:<a href="http://www.tankguys.biz/ddr2-3338-p-1692.html" target="_blank">http://www.tankguys.biz/ddr2-3338-p-1692.html</a><br />
<br />
For the best deal on good overclocking DDR2 for Conroe, I'm gonna agree with boredom. That Crucial Anniversary RAM is excellent, and has easily hit 1000+ MHz at good timings.</div>
</td>
</tr>
</table>
</div>Agreed, this stuff has hit some very impressive speeds. Close to ddr1100 with the right system.<br />
<br />
The ram Boredom recommended will be what im getting for my C2D setup.<br />
<br />
Either set will do just fine, although the Team chips will overclock better while providing a better stock rated speed.
That is a bit expensive for D9s. <br />
<br />
I'd recommend the G.Skill DDR2 800 HZ: <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16820231065" target="_blank">http://www.newegg.com/Product/Produc...82E16820231065</a><br />
<br />
Or the Xtreem DDR2 800: <a href="http://www.tankguys.biz/ddr2-44410-800mhz-p-1645.html?osCsid=f5d8004939518dcfa6dfd393392e13c3" target="_blank">http://www.tankguys.biz/ddr2-44410-8...dfd393392e13c3</a><br />
<br />
Those two kits are very likely to hit DDR2 1100 speeds w/o a sweat and you save $133 which you could use to upgrade to something else. <br />
<br />
And yes, don't look at the Corsair XMS2, they're good and use D9s but they're way overpriced IMO.
Discussion Starter #12
Lol now with so many options I can't decide! Heh, I will try to do more research, but thanks for the opinions! <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" />
All three highly recommended memory choices (xms, gskill, tank) are all about $300 for 2GB kit. XMS 2GB kit has a $40 rebate right now.
<tr>
<div>
Originally Posted by <strong>dvast8n</strong>
<a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1398714#post1398714" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">All three highly recommended memory choices (xms, gskill, tank) are all about $300 for 2GB kit. XMS 2GB kit has a $40 rebate right now.</div>
</td>
</tr>
</table>
</div>The thing is that all the high end memory sticks have the exact same chips as the Crucial I posted while costing as much as $80 more
<tr>
<div>
<a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1398729#post1398729" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">The thing is that all the high end memory sticks have the exact same chips as the Crucial I posted while costing as much as $80 more</div>
</td>
</tr>
</table>
</div>Keep in mind that the sets recommended were for ddr2 800 while the Crucial is only 667.<br />
<br />
You aren't paying the extra $80 for nothing.
<tr>
<div>
Originally Posted by <strong>TheLegend</strong>
<a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1398740#post1398740" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">Keep in mind that the sets recommended were for ddr2 800 while the Crucial is only 667.<br />
<br />
You aren't paying the extra $80 for nothing.</div>
</td>
</tr>
</table>
</div>It's the same D9GMH chips, Crucial could have attached a ddr2 -10000 tag and it would still OC the same as the ddr2 800 sticks
<tr>
<div>
<a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1398768#post1398768" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">It's the same D9GMH chips, Crucial could have attached a ddr2 -10000 tag and it would still OC the same as the ddr2 800 sticks</div>
</td>
</tr>
</table>
</div>You'll be more likely the hit ddr1000 with the Xtreem versus the former.<br />
<br />
Much harder for 667 to hit 1000 than 800 to hit 1000.
<tr>
<div>
<a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1398783#post1398783" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">You'll be more likely the hit ddr1000 with the Xtreem versus the former.<br />
<br />
Much harder for 667 to hit 1000 than 800 to hit 1000.</div>
</td>
</tr>
</table>
</div>D9GMH is D9GMH, they'll pretty much all hit 1000+
<tr>
<div>
<a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1398792#post1398792" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">D9GMH is D9GMH, they'll pretty much all hit 1000+</div>
</td>
</tr>
</table>
</div>A +3700 is a +3700, but not all will hit 3.0. There is a reason why chips are rated the way they are.<br />
<br />
If you can show me a link where the Crucial hit close to 1000 i'll be satisfied.
<tr>
<div>
<a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1398450#post1398450" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">Crucial Technology 2GB $230<br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16820148017" target="_blank">http://www.newegg.com/Product/Produc...82E16820148017</a></div>
</td>
</tr>
</table>
</div>wish i could find that ram in canada <img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" />
1 - 20 of 27 Posts
