1 - 4 of 4 Posts
4000PT 2GB would be my choice. 2 X 1GB will not make your controller work as hard as 4 X 512 and you will achieve better timings on your overclock.
You are overclocking? If not then get dram that allows you 2-2-2-5 @ 200MHz fsb.
R
I remember when......
Should you fill all 4 slots?
Sure, if you want/need that much RAM.
I would go with the TWINX2048-4000PT, it's faster speed AND they have it tested at 250FSB, which will make OC at 1:1 easier, and pretty good timings there.
If your board supports dual channel, be sure to install them in those slots and make use of that.
I would see about selling the 2 sticks of 256 you have, wouldn't make a huge difference since you would already have 2GBs, and they would pull down the new sticks to 3200 speed, kind of negating the point.
1 - 4 of 4 Posts
