which ram should i get
271 Views 7 Replies 5 Participants Last post by  18 is # 1
1 - 8 of 8 Posts
Id go with either the corsair or the patriots, those pretty much mach up equally, and have slightly better timings. But if you dont wanna mess around with the MIR go for the gskill.
how do u recieve the rebate as a check probably right?
The Corsair Dominators are both very good and OC well.
If you want G. Skill, get these - http://www.newegg.com/Product/Produc...82E16820231166
You send them a form with the UPC or proof of purchase and 6-12 weeks later, you get a check.
Make sure to MAKE COPIES of everything you send them.
Yup it will be a check that comes in the mail and you just case it like normal.
Corsair FTW!!!
i think ill get dominators-is the fan worth it?
No. Those run cool. You wont need the fan if your case has decent airflow.
1 - 8 of 8 Posts
