Which ram?
431 Views 10 Replies 10 Participants Last post by  superon
Hi guys
Which ram should i get?
Mushkin DDR2-800 RAM
> DDR2-800
> 2.0-2.1 V
> 4-4-4-12 Latenzen
> Bezeichnung: 996580 PCGH
> XP2-6400
Or:
G.Skill 2x 2048MB DDR2 PC1000 RAM CL 5-5-5-15 / F2-8000CL5D-4GBPQ
I want it for getting my Q9450 too 3.8 ghz
1 - 11 of 11 Posts
G.Skill is better
you get higher Mhz even if it has looser timings, its still better overall
I think you should get the G.Skill PC2-8000(1000MHz) PI RAM for only $5 more or the 1066MHz version of that RAM for only $10 more.
Make sure you get a better CPU HSF for overclocking.
@Dark Volker those are too big since i got a z600 cooler
@Cryptedvick i will bid on the g.skill then
I would bet the Mushkin will go higher. If those GSkill could hit 1066, they would be binned in 1066 sticks. My Mushkin are stable to 1110 MHz.
i might get the gskills dude, ive heard they are cheap and very reliable.
Yea I'd think the mushkin would be able to go higher.
I would get the mushkin. CL4 @800 is better than [email protected] CL5. Plus you can OC so I mean not really a question anymore. And neither make the DRAM so not sure what this whole this is better than that talk is about between these two? What G.Skill makes a great PCB? OK what ever?
G-skill PI's -- for $5 more, no contest.
1 - 11 of 11 Posts
