1 - 5 of 5 Posts
OCZ Value / KINGMAX / KINGSTONE
with soyo dragon lite with 1.2 amd?
which one will be better?
aiming at 512 memory size one stick.
and i belive the max should be 400DDR i don't think the board will do 466
any ideas?
Are u sure your mobo takes ddror sdram? If u have ddr, then any of those should be fine, but its all about the timings and voltages...ocz value is supposed to be very good, and that's probly what I'm gunna recommend...but I don't even think u need ddr400 for a athlon runnin at 1.2 but I guess it will last longer....
it does 400
so i dono i like ocz but kingmax has 2.5 timing
where oz has 3 !
1 - 5 of 5 Posts
