1 - 7 of 7 Posts
PC Evangelist
You are comparing 2 vs 1 when they are the same price. Not much increase from current Raid.
I wasn't comparing to price. I was comparing 15000rpm and 10000rpm hdds.
here is a benchmark of 3 of those drives in raid 0 on a Dell Perc5i 8x card running at 4x, Im not sure if I can get more out of them with an 8x slot but I will really see the difference out of them since I cant run 4x without losing my tv tuner and external SATA card that are plugged in the other slots.
Perc5/i 3 fujistu 73GB SAS drives on a 4X slot 128mb test
Perc5/i 3 fujistu 73GB SAS drives on a 1X slot 128mb test
The 3.5in SAS drives are old, the newer 2.5in SAS would be better but I got these for free.
AS 396507
Originally Posted by NewAtOCing View Post
So just out of curiosity which would be faster?
what do you mean, faster? access times would probably be faster with the 1 scsi drive, but bandwidth is probably going to be better with any two sata drives in raid-0. so are you looking for torque or horsepower?
edit: i hope youre' not thinking about putting a SAS drive on a sata port...
What's wrong with using a SAS drive on a SATA port? Won't it work if you had an SAS to SATA adapter?
1 - 7 of 7 Posts
