Hey guys so everyone that helped me thus far have now completely convinced me to do custom cooling, now i need a case, shud i get the STH10 OR the TH10 from caselabs????
The TH10 has two seperate compartments. The MB is on one side and the PSU is on the other, along with enough room for pumps and everything else. You can check an old thread of mine to get some idea of how big it is. http://www.overclock.net/t/1051357/caselabs-th-10-build-log-madnessOriginally Posted by islandgam3r
thx for ur input everyone, i DO plan on benchmarking. Quick question, does TH10 have 2 separate sides/compartments? like can u have mobo on one side of case and the other components on the other? if so, does STH10 have same dual compartment as TH10? Just curious cuz on caselabs site it looks like the TH10 DOES have separate compartments on either side of case, not sure about STH10.
Please, any info will b appreciated.
I saw your rig...its pretty sweet man, I want my rig to be as clean as possible, like yours and maximum cooling for all components and high airflow setup so case can have adequate ventilation.Would u recommend the TH10 or STH10? also, wats the height diff between the 2? and If i am going for extreme OCing on cpu, do u recommend xspc 240 Kit, 360 kit or 480 kit? twin d5 pumps or Raystorm 750 single pump? OR the swiftech MPC655? Also wat tubing do u guys recommend, as I plan to use compression fittingsOriginally Posted by theseekeroffun
Thanks, I am in the process of building a new one. The TH 10 is easier to work with due to the extra space. The STH is about 7" taller, but the TH is 4" wider. Personally, I like the look of the STH better, but it was not available when I bought my TH. However, I love my TH along with the pedestal and you cannot go wrong with either one.Originally Posted by islandgam3r
Let me know your thoughts
Both will have enough room but the TH10 will have more room. STH10 is a standardized single compartment computer case but its a Case Labs so of course it is not like a regular computer case. If you like the look of a standard computer case, get the STH10. If you want something different with more room, get the TH10.Originally Posted by islandgam3r
My current rig I had for 6 years air cooled still running, but i refuse to go through the specs due to how EMBARRASSINGLY OLD ALL MY PARTS ARE (LOL)this will b my first attempt at watercooling...![]()
but to date i still think i have one of the BEST EVGA mobos ever made, and it pisses me off that i didnt use it to its full potential and now i am trying to sell my current rig..... for some DOSH =(
Also I like the look of STH10 better also, but I LOVE the fact that you can hide a bunch of hardware in th10 and how the mobo has a separate side for itself. Do u think if I plan to expand my hardware later down the road will STH10 be enuf room? and for my build wat rad sizes and kits do u recommend??
The MB area is basically the same size in both case's. Belive me, an extended MB still gets lost and adding more VC's won't make any difference either. With what you have configured, you will have enough room with either case.Originally Posted by islandgam3r
I was planning to cool the CPU, 2 GTX 4GB ACX Superclocked 770s in SLI and possibly my NB. At some point down the road, I plan to have 3way or 4way SLI.
CPU: 4770k (OC to 4.5GHZmin. - 5+GHZ MAX)
GPUs: 2 EVGA SC GTX 4GB 770s (Also Plan to tweak a little bit more than factory OC)
MOBO: MSi Z87 XPower
Plan to do 1 loop to cool all components
RAD#1 for CPU- XSPC AX360 Kit with dual D5 pumps w/AX480 Rad instead of 360
RAD#2 for Vid cards: Alphacool NexXxos Monsta Quad 120mm Rad
Plan to use dual pumps for entire loop and i am getting a RAZOR XSPC water block for the 770s
Wat would u guys recommend for this config, with possibility of expanding up to 4way SLI and also cooling NB the STH10 or TH10?
