1 - 9 of 9 Posts
i am going to bay a new CPU can some one tell me which should i get?
939/3700+/2000MHzBUS/1MB L2
OR
754/3700+/1600MHz BUS/1MB L2
right both CPU are 249.99 is that a good price?
is gonna be for gaming
Definately the 939 3700+, I believe that one is SD too, And from what i heard, it overclocks to FX Speeds/ 4000+ AMD Speeds. Besides, the SKT939 is new technology, so youll be futureproof for alot longer. Ultimately, even if the 3700+ skt939 is not SD core, its ok. =)
Originally Posted by ghostlove
i know this is stupid but what is SD mean?
SD = San Diego. ( Core)
Go with socket 939. You will have more upgrade options in the future.
Plus, the S939 CPUs have better memory controllers. The SD 3700+ overclocks pretty good too from what I heard...
1 - 9 of 9 Posts
