Originally Posted by wildboyz;14185222
I'm using realtemp 360. My load temps are up to the 70s C but my cpu temp only goes up to 50 C or so...is that considered high? Did I do something wrong or do I just have a faulty H50?
I'm also using a push pull config with the stock corsair fan pushing and cooler master fan R4 fan pulling.
Also, when people report their temperatures, do they just report the highest temps out of however many cores they have?
CPU are made of several cores. So CPU = one or more Core put together.
If you see "CPU Temp" it is usually the highest core temp.
Core temp are, of course, each core temp.
So if the CPU Temp showing something other than what your core temp is at, it is most likely a false sensor reading.
The latest version of RealTemp shows the most accurate core temp. So forget about CPU temp. Just focus on each core temp especially when you are OC since each core heats up differently.
