which tempreture is the one to look for? core / cores tempreture or cpu temreture?
428 Views 7 Replies 7 Participants Last post by  kpo6969
cuz my cpu temp is always higher than core temps
1 - 8 of 8 Posts
I would just go off the CPU temp to be safe
The temp that most temperature programs and the BIOS output as "cpu temp" is either the temperature of the Internal Heat Spreader (the metal soldered to the CPU) or the socket that the CPU is in.
The temperature that you want to watch is the core temperature. RealTemp, CoreTemp, and HWMonitor are some good temperature programs that display core temperature.
Quit making things difficult.
Just watch the CPU temp, do not bother with the core's... there should not be much difference though maybe 3-5C.
Making things difficult? I think alot of people her watch the core temp as opposed to the CPU temp. Also, the difference between the core temp and CPU temp can be way more than 3-5C. At full load my Q6600 CPU temp is 10C lower than my core temp. Besides the temperature sensor that the CPU watches to determine when to thermal throttle, is the *core temp*.
I'm just trying to share some info with the OP. Why don't you make things less difficult by trying to act a little more professional.
I watch cores. Right now my cpu temp is 22 and my hottest core is 38. Big difference!
I only watch the core temps and nothing more.
Short, to the point, and correct. ^
1 - 8 of 8 Posts
