1 - 11 of 11 Posts
personally i would go with teh shark as it is a full size case so will help with air flow and also alowss for larger heatsinks as it is slightly wider i use the xaser 111 just for that reason have changed the 800mil fans for some 120mil fans and works a dream . that case comes with 120mils as standard
yes the shark one is better :) have a nice evening!
Originally Posted by Bszx
I like both but with the shark you cant see the guts of your system, which is usually fun....
Yeah, IMO a window is a must.. But you cant go wrong with either case.. They're both bad ass.
1 - 11 of 11 Posts
