1 - 5 of 5 Posts
So I've been wanting to either get water or phase cooling for quite some time now, and I was wondering which one would be the best for me. I am on a budget, so would it be better if I make my own custom water/phase or should I buy a kit. And also what would be the pros and cons of each? I'm not really concerned with noise, as I used to have a vantec tornado but just so long as its bearable.
I see so if I get water what would be the pros and cons and Ill probably upgrade to AMDs quadcore when it comes out so what would be better in the long run
It all depends on how much cash you have, if you only have 220-270 to spend, get water, if you have oodles of money, get phase.
Reactions: dexterousdeven
1 - 5 of 5 Posts
