which VGA card is best for 380W PSU
377 2
my computer specifiction is below
this is my PSU : http://www.coolermaster.com/index.ph...20Power%20380W
I'm gonna change my FX 5700 by a Geforce 6600 GT or 9800Pro or 9800XT I'm oC'ing my CPU from 2.2GHZ to 2.4GHz vcore @ 1.350 x 113%=1.526 v
I dun wanna chang my PSU 'cause I've just bought it 2 week ago !!!
I wonder is my PSU enough for that card ( I dun use Sli tech, just 1 card) ??
If that card is too much for my PSU !!!
Could you suggest me another card that better than FX5700 and my PSU can handle it !!!
Thanks so much
__________________
1 - 3 of 3 Posts
well it should handle a 6600GT... but I wouldn't plan on OC'ing too...
but the 6600GT would be the best card to get
If your PSU doesnt undervolt.. at least not too much, then you should be fine. You might be able to OC a bit as well. When I had first bought one of my 6800gt's I was running a Antec True 380w.. and it handled it just fine. Also, depends on how much stuff you are running in your comp as well.
1 - 3 of 3 Posts
