I ordered 2 2"x2"x3/4" copper blocks from danger den. At only $12 for the pair, im sure I could make a couple water blocks worth the money
Im gonna drill into the blocks to make the channels, and plug up the holes I dont want with jb weld.
Which design out of these three do you think would be best? And do you know of any other designs that are easy? Im probably gonna end up doing two of the designs, since I got two blocks, there gonna be used on my cpu and gpu. Im kinda liking number 3
gold = block, blue = water, red dot = exact center (pic isn't drawn good at all), red lines = holes imma drill and fill with jb weld
edit: should probably include this
pic 1 : 1/2" main holes, with 3/8" holes connecting the sides together
pic 2 : 1/2" main holes, 1/4" holes connecting
pic 3 : 1/2" holes all the way around
