which way
198 Views 1 Reply 2 Participants Last post by  Acoma_Andy
hi, i have a zalman 9900 coming from newegg, and i have a question. which way should i have it settup to blow air? my case has an 80mm fan on the side oppostie the mobo/cpu pulling air in. it also has one on the top of the case, which is a bit more towards the front. it's kind of like
fan here
_____V___
| _ | front of case
| l_l here |
|________ |
so do you think i should have the fan blowing air toward the front or back of the case? the cpu is right behind the side fan.
1 - 2 of 2 Posts
Let it blow towards the back of the case. And if there's room for another fan at the back, put a 120mm there also.
1 - 2 of 2 Posts
