1 - 7 of 7 Posts
The Silverstone or the Zalman9500 would be the best ones. I hate Fatal1ty crap and that other Zalman8000 is a bit too small so it won't cool as great.
the fatal1ty is crap because of ?
because it is horrible at cooling and fatality's name on it
the cpns9500 is probably the best, but is overpriced and get outperformed by a thermaltake big typhoon
If any of those, I'd pick the 9500, but I'd never pick that one ever.
Get a Scythe Mine or Scythe Infinity and mount a nice fan on it.
Go figure with The Villain (Villainstone), 25c LOAD on a Scythe Mine.
Discussion Starter #7
that explains alot
i don't even like UT, i'm a ET gamer
that depends on alot of things cause if some1 has the same cooler but diff hadrware, case etc the temperature would probably different
Then i probably would go for the SST-NT06 or the CNPS9500
1 - 7 of 7 Posts
